Activity Forums VEGAS Pro Please Check My Render Settings
  • Please Check My Render Settings
    Posted by Jeff Andrews on November 24, 2010 at 6:54 pm
    Hi, I’m working with a bunch of mpg files, converted from VOB after I converted my old VHS tapes to DVD using a DVD recorder. I know, not the best option, but it happened years ago and I’m actually pleased with how the mpg files turned out.
    I’m now using Vegas Pro 9 to edit the mpg videos, add graphics, and eventually render them to DVD. Only standard quality is needed, and the end result will be about 35 DVDs with roughly 75-90 minutes each.
    These are the project properties and render settings I plan to use. Please let me know if you have any suggestions that might improve the final result, thank you:
    Nigel O’neill replied 15 years, 10 months ago 3 Members · 3 Replies
  • John Rofrano
    November 24, 2010 at 11:47 pm
    Why did you change your Deinterlace Method to None? this is going to make a mess of your video. Set it back to Blend Fields!
    For your project settings, I would not have changed the Pixel Format or the Compositing Gamma from the defaults. Unless you have a specific need to use 32-bit, I would use the default 8-bit.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeff Andrews
    November 25, 2010 at 2:28 am
    Hi John, I’m brand new to Vegas and video editing in general. I changed the deinterlace method and the result was a video with less blur than before on the motions in the video. So thank you for the advice.
    I tried your other advice as well but for my project it ended up looking much better as 32-bit. At 8-bit, the video jumped and the motions were not smooth.
  • Nigel O’neill
    November 25, 2010 at 6:31 am
    Jeff
    You might also want to try 2 pass VBR rendering under the custom settings of the render template, and use a bit-rate calculator to determine the best low, average and high settings. I am assuming your video is over 60 minutes long.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (X64), Vista x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S 4.1
