Activity › Forums › Adobe After Effects Expressions › Please assist with simple script
  • Please assist with simple script
    Posted by Syed Iqbal on June 27, 2015 at 5:38 pm
    Hi folks
    I have written 2 simple lines of code by taking online help. The code makes a duplicate of current layer but I am not being able to figure how can I turn the visibility off of the previous layer which was used to create this duplicate:
    var myComp = app.project.activeItem;
    var myLayer = myComp.layer(1).duplicate();
    I have tried something like this but it does not work:
    myLayer.index(-1).disabled;
    It seems I am not using correct syntax. Please help.
    Regards
    Syed
    Syed Iqbal replied 11 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 27, 2015 at 6:28 pm
    Try it this way:
    var myLayer = myComp.layer(1);
    var myNewLayer = myLayer.duplicate();
    myLayer.enabled = false;
    Dan
  • Syed Iqbal
    June 27, 2015 at 6:33 pm
    Hi Dan
    As usual you have advised an awesome trick. I have also tried the below code and it is also working:
    Thank you very much once again for your help.
    Regards
    Syed
    myComp.layer(2).enabled=false;
