Activity Forums VEGAS Pro Please advise on this custom transition
  • Please advise on this custom transition
    Posted by Valerie Lane on April 5, 2009 at 4:17 am
    I have been wanting to use the effects that I saw in the video below that was done by someone else (and I don’t even know what program they used). I have Sony Vegas Pro 8.0
    Would you please help?
    https://www.flickr.com/photos/36855828@N04/?saved=1
    You can see the effect in the middle of the video, around 44 seconds counted down. It involves a swipe transition that also uses a desatured/tinted video. Any ideas how I can do that? In this clip, the swipe is full-screen, over a smaller screen.
    must_be_dreaming
    John Rofrano replied 17 years, 5 months ago 3 Members · 5 Replies
  • Graham Bernard
    April 5, 2009 at 5:42 am
    The timings on that sample were out of whack? So if I am looking at what you provided as correct then try this:-
    1] Track1 has the overlay of the slanted Desat+Red media. Create the slant by using Bezier Masking.
    2] Using Track Motion move the Track 1 Event from Right to Left
    Grazie
  • Valerie Lane
    April 5, 2009 at 4:40 pm
    Thanks for that, but I’ve already tried the Bezier (iunless there’s a trick I don’t know)…I have more specific questions. The scene I refer to is midway in the video when the song lyrics is “I must be dreaming…” and the color transition occurs.
    I want to know specifically how that video did the following:
    1) transitioned from the entire video in black and white and had a “sweeping” transition that had the effect of putting in color into the screen from left hand side to the entire screen. If you notice, it’s NOT a simple effect of changing the entire video to B&W or sepia.
    (I’ve figured out that there needs to be 2 identical videos, one pure black, one pure color, on separate tracks that have a lag in time so that you see the sweep).
    2) In the “sweeping” transition, it is just a SLIVER/small PIECE of video, and that part is desaturated and colored. But the rest of the color that it sweeps in is normal color (not desat). How do I use that SLIVER of video? Like, if I use a video, how do I time it so that it exactly matches the smaller scene that’s occupying the entire screen? How do I make the sweep go faster/slower? I don’t want to use just some random scene as that SLIVER of transition.
  • John Rofrano
    April 5, 2009 at 5:12 pm
    It looks like the sliver of video is on a third (top) track. To sweep from B&W to color: Track 1 has the sweep video with bezier mask applied to make the diagonal slice. Track 2 is color video track also uses an animated bezier mask to slowly reveal the video on a diagonal from left to right. Track 3 is just B&W video. You need to make sure that the keyframe animation on the bezier on track 2 reveals the color video at the same rate that the video on track 1 sweeps across.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Valerie Lane
    April 5, 2009 at 5:55 pm
    thanks, that makes sense. On the Track 1 Bezier mask, though…
    When I tried to move the actual mask from left to right, it won’t move (I’m new to vegas). Do I need to make individual keyframes across to do that? And even when I do, it won’t be a smooth sweep, then. It’ll just be a mask here, then it’ll pop up in another area, and so on, across the timeline of the clip.
    I tried to use other methods, like with a LINEAR wipe, and then put that resulting video onto this project. It’s decent, but NOT AT ALL how the video shows a larger desaturated/blue video sweeping across. Just wondered if there were some trick to getting that overall appearance/effect.
    I also want to get a transition border like the one on the video link using Vegas (if that effect’s unique to another like Adobe, then nevermind).
    Thanks so much for the help you’ve already given!
  • John Rofrano
    April 5, 2009 at 11:35 pm
    Moving the mask is a bit tricky. What you do is select one of the points with the arrow tool and then right-click it and choose Select > All. Once all of the points are selected, you can click on any one of them and drag it to move the entire mask.
    The animation can be accomplished with just two keyframes. Select the first keyframe and move the mask off the screen to the left. Move to the end of the keyframe timeline and add a keyframe at the end. Select it and move the mask all the way off the screen to the right. These two keyframes should make the mask flow smoothly from left to right. Do the same with the Bezier mask on the color video track to reveal the color over the B&W track. It will take a little playing to get the two masks to flow together.
    ~jr
