Activity › Forums › Apple Final Cut Pro Legacy › pleasantville effect on two colors
  • pleasantville effect on two colors
    Posted by Michael Hampshire on August 27, 2010 at 9:49 pm
    Hey guys I have some footage where two groups are painting using to different colors one color red and the other yellow. My question is how would I do the pleasantville effect on BOTH red and yellow. I know how to do them separately but not sure how to make both the yellow and red show up with everything else black and white and everything i have been trying isn’t working. Any help?
    Mark Suszko replied 16 years, 1 month ago 4 Members · 3 Replies
  • John Fishback
    August 27, 2010 at 10:20 pm
    I’ve never done this, but after you’ve treated the two clips to isolate the two colors, perhaps, you can key one of them based on its color and then invert the key.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Scott Sheriff
    August 27, 2010 at 10:24 pm
    I was thinking the same thing. Or maybe use a keyframed mask, or even a simple wipe between the two. Depending on where the two colors are in the frame.
    Scott Sheriff
    Director
    SST Digital Media
    https://www.sstdigitalmedia.com
  • Mark Suszko
    August 28, 2010 at 2:57 am
    Try a blend mode change and some fussing with opacity between the two treated layers.
