Activity › Forums › Adobe Premiere Pro › Playing timeline stalls every 12-14 minute
Posted by Michael Dunlop on December 10, 2005 at 3:01 pmThe 33 minute show I edited in PP 1.5 does this and I have to tap the spacebar to get it moving. I
Michael Dunlop replied 20 years, 9 months ago 3 Members · 5 Replies -
Aanarav Sareen
December 10, 2005 at 8:12 pm -
Michael Dunlop
December 11, 2005 at 1:39 amI ran express test in Dell diagnostic and got no relevant error messages.
Aanarav Sareen
December 11, 2005 at 2:42 amHmm…This may be a little frustrating, but how about opening up the task manager (Ctrl + Alt + Del) while the video is playing to see if any of the processes or applications are “spiking” during the time when the video stops. I had a similar problem (except, mine would stop every 20 seconds) and it turned out to by my anti-virus software. But, since you say that yours is turned off, it may be a little harder to pin point.
Mike Velte
December 11, 2005 at 12:30 pmTry this;
Solution 2: Change the affinity setting for the Adobe Premiere Elements.exe or Adobe Premiere Pro.exe process to use only one CPU.
To change the affinity setting:
1. Start Premiere Elements or Premiere Pro.
2. Press Ctrl + Alt + Delete and then click Task Manager.
3. Click the Processes tab.
4. Right-click the process Adobe Premiere Elements.exe (or Adobe Premiere Pro.exe), and then choose Set Affinity.
5. Deselect all CPUs except the first CPU listed (CPU 0), and then click OK.
6. Quit the Task Manager.
Michael Dunlop
December 11, 2005 at 6:24 pmMike,
You da man!! That solved the problem. I’m so relieved. Thanks.
