Activity Forums Apple Final Cut Pro Legacy playing HDV finished edit out of FCP to Z1 sony camera
  • playing HDV finished edit out of FCP to Z1 sony camera
    Posted by Matthew Rumsey on June 25, 2009 at 11:36 am
    any advice would be much appreciated –
    background:
    hardware g4 apple
    Sony Z1 HDV camera
    software – osx 10.5
    final cut pro – 6.0.5 version
    here is the problem:
    I have an edit of 10mins and am trying to play it out of final cut pro back into the camera.
    it was shot and captured in HDV
    edited in HDV
    the audio/video setting i have in FCP are :
    sequence preset -HDV – 1080i50
    capture present – HDV
    device control preset HDV- 1080i50 firewire basic
    playback output video – (ONLY ABLE TO SELECT – ‘NONE’ OR DIGITAL CINEMA DESKTOP’
    Camera settings: VCR HDV/DV : HDV
    i.link conv : off
    a/v -DV out: off
    i have played around with the setting of both but the best i can do to get the picture out is down convert them to DV and they they appear squeezed with black boarders top and bottom – please can anybody confirm what the setting should be to play the HDV edit out onto the camera???
    does the Tape i am playing onto have a bearing? it is a sony DV tape – not sure if this is the problem though as the camera and final cut do not recognize each other before we even get to pushing record on the tape.
    Matthew Rumsey replied 17 years, 2 months ago 3 Members · 5 Replies
  • Tom Wolsky
    June 25, 2009 at 11:54 am
    You cannot play HDV back to tape. You have to use the print to video function. Is that what you’re doing? What exactly happens when you do it?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Matthew Rumsey
    June 25, 2009 at 12:31 pm
    really.
    yes i was trying to slave it direct to the camera as i have done with standard def –
    am now trying the print to video function – it is currently rendering it _42 minutes remaining – camera set ready to record – thank you tom
    will let you know the outcome.
    matt
  • Matthew Rumsey
    June 25, 2009 at 1:30 pm
    hi Tom
    i tried the print to video function –
    the pictures rendered for 42 minutes – went to a black screen and a message appeared asking me to push ok – the progamme started to play on the screen – (although not full screen inside a black box three quarter screen size – although the camera did not record it.
    the camera is plugged in via firewire –
    matt
  • Jerry Alto
    June 25, 2009 at 10:08 pm
    Mathew- Did you follow the directions in the dialog box? First it goes through a ‘conforming’ process. This is where FCP is building the proper frame structure for HDV output. The camera has to be in VCR mode and connected via firewire while it is conforming. When it’s done you’ll get a dialog box saying to put the deck in record mode. Push play/record at the same time and let the tape record for 5 to 10 seconds THEN click the OK on the dialog box. There is a delay between the video on the computer screen (cinema screen) and the LCD on the deck.
    With HDV you have to use Print to Video which requires doing ‘hard record’ without machine control.
    HTH,
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
  • Matthew Rumsey
    June 26, 2009 at 8:05 am
    Jerry
    cc Tom
    thank you
    yes have made it work now
    the crucial piece of information for me was don’t turn the camera off while it is rendering! i was saving the bat power because the render takes over an hour – but this was causing it not to work.
    thanks to both of you
    Matt
