Activity › Forums › Adobe Premiere Pro › Playing back HD video on Canon XHA1
  • Playing back HD video on Canon XHA1
    Posted by Kev Stevenson on October 25, 2009 at 9:27 pm
    Apologies in advance if I have posted this in the wrong place, I’m sure someone will be able to advise where I should have posted it?
    I Have only just joined this forum so it’s all a bit new to me at the moment
    I need some help with my Canon XHA1 – I have been using it for a couple of months in std mode (16.9) with no problems
    Juts started to try out the HD mode and have set this in the signal setup (HD)
    However when I try to play it back on the camera I just get a message stating “Playback std locked – Playback is retsricted”
    Can anyone help me please, as I have to resolve this before I even try capturing onto Adobe Premiere CS3
    Thanks in advance for any help
    Kev
    Need some help please with playiong back HD video recorded on a canon XHA1?
    Kev
    Mike Velte replied 16 years, 11 months ago 2 Members · 3 Replies
  • Mike Velte
    October 26, 2009 at 10:36 am
    The camera’s playback mode must match the format on the tape (HDV or DV) AND Down-convert turned off. Then your Project/Sequence settings must be HDV.
  • Kev Stevenson
    October 26, 2009 at 10:41 pm
    Mike
    Thanks very much for the prompt reply to my request for help.
    3 further questions in response to your reply (will show just how new I am to HD)
    1. Do I have to buy specific HDV tapes or can I still use the
    standard DV ones I havce been using
    2. Where do I find the Down-convert option to enable me to turn it
    off – how do I turn it off (is it just a menu option as others
    are and I selcet the appropriate option)
    3. You say the Project/Sequence settings must be HDV – again where
    do I find this option on the camera?
    Sorry if these appear (or are) really dumb questions but when evertything is new to you even the basics can be a bit daunting until you have done them once or twice.
    I hope you can again help me with my problem
    best regards
    kev
    Kev
  • Mike Velte
    October 27, 2009 at 10:45 am
    1. Tapes are the same.
    2. There is an option in the camera to down-convert HDV to DV during capture in the camera.
    3. Project (CS3) or Sequence (CS4) settings are Premiere settings that must match the format of video coming from your camera…HDV or DV.
