Activity › Forums › Adobe Premiere Pro › Playhead not following audio in Source monitor
  • Playhead not following audio in Source monitor
    Posted by Yannik Bachmann on September 23, 2014 at 11:53 am
    Hello,
    I have a problem with Premiere Pro CS6 on a MacPro.
    When I “view” an audio clip in my source window, the audio is played back correctly. The playhead however is not keeping up with the audio which I recognize when setting IN and OUT points while playing back audio.
    The positions of IN and OUT are sometimes off by a few seconds. The longer I play back audio the more it is off…
    I am using a Focusrite Liquid Saffire 56 external sound card but this is also happening with the built-in Line output.
    My MacPro: OS X 10.9.4 (13E28)
    CPU: 2×2,6 GHz Quad-Core Intel Xeon
    RAM: 20 GB 1066 MHz DDR3 ECC
    Graphics: ATI Radeon HD 5770 1024MB
    external sound: Focusrite Liquid Saffire 56 (via Firewire)
    If you have any suggestions, I’d be really grateful.
    Thanks.
    Jerry Wise replied 12 years ago 2 Members · 5 Replies
  • Jerry Wise
    September 23, 2014 at 1:27 pm
    is your playback set to full resolution.?
  • Yannik Bachmann
    September 23, 2014 at 1:37 pm
    Thanks for your reply.
    I don’t think you can set any kind of resolution for audio clips, can you?
    I’m talking about the source monitor. Once it’s in the program timeline everything works as it should.
  • Jerry Wise
    September 23, 2014 at 4:04 pm
    I can make premiere do what you are talking about right now.
    in the source window drop in a video clip and make sure that your resolution is set to Full. then go back to marking and editing audio.
  • Yannik Bachmann
    September 23, 2014 at 4:08 pm
    I already did that. It has no effect on audio, though.
  • Jerry Wise
    September 23, 2014 at 4:55 pm
    must be a bug.
