Activity Forums Avid Media Composer Playback to Client Monitor through 1394 Cable
  • Playback to Client Monitor through 1394 Cable
    Posted by Daniel Addelson on March 9, 2007 at 6:23 pm
    This seems like it should be a simple fix, but I can’t seem to figure it out. I am trying to send playback through the firewire cable to a deck and out of the deck to the client monitor. I am able to successfully playback all the way to the client monitor during a digital cut, but not in source/record mode. I tried turning off real-time effects to no avail. Is there a setting I need to change somewhere?
    Daniel Addelson replied 19 years, 6 months ago 3 Members · 4 Replies
  • Michael Phillips
    March 9, 2007 at 9:58 pm
    Are you in green/green mode?
    anything 24fps
  • Daniel Addelson
    March 9, 2007 at 11:22 pm
    I was in blue dot mode, but I figured it out – looks like I just had to change a setting on the deck. Thanks for your help.
  • Michael Hancock
    March 10, 2007 at 2:11 pm
    What deck were you using and what setting did you have to change? It might help future users if they run into the same problem and search the forums.
    Michael.
  • Daniel Addelson
    March 12, 2007 at 8:32 pm
    I am just using my mini-dv camcorder as a deck (Sony TRV-17). There is a setting on the camera to switch A/V in or out. Just got a second monitor and DVI to ADC converter to make it all work. So nice to have all that workspace.
