Playback through Blackmagic Decklink to an LCD TV
Hi
I am hoping that someone could shed some light on an issue I am having with premiere pro Playback to a Full HD LCD TV via a Blackmagic Decklink card.
The TV can only take two 1920×1080 inputs. That would be at 50i and 50p. This playback works on a 50 FPS timeline but when I make a 25fps timeline it won’t output at 50i or 50p to the LCD TV. Kind of an issue considering all of our working timelines in Premiere will be 25FPS.
Just curious as to why Premiere pro can’t use similar Playback options to After Effects where you can set your playback options regardless to what timeline/composition you are currently in.
Does anyone have a similar issue with Premiere Pro and Blackmagic cards or a fix?
