Activity Forums Apple Final Cut Pro Legacy Playback stopping due to dropped frames
  • Playback stopping due to dropped frames
    Posted by Ezio Taranto on March 16, 2006 at 12:09 pm
    While viewing my playback in RT hi res – fully rendered – the system warning for dropped frames pops up and ruins the show.
    i have attempted all the suggestions it offers, but the problem persists.
    can you help?
    Ezio
    Kevin Monahan replied 20 years, 6 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    March 16, 2006 at 12:37 pm
    Did you try this?
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
  • Kevin Monahan
    March 16, 2006 at 7:47 pm
    If audio mixdown won’t work, your drives are too slow or are being hindered somehow by your setup. If they are daisy chained to a slow video camcorder (many are FireWire 200), then all connected drives will slow as well causing dropped frames.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
