Activity › Forums › Apple Final Cut Pro › Playback stall after deletion
  • Playback stall after deletion
    Posted by Oliver Peters on December 6, 2015 at 1:50 pm
    I see this on FCPX and I wonder if others are experiencing this, too.
    I’m editing along happily in my timeline deleting excess material. Occasionally I delete a section and when I go to play it, nothing happens. The viewer displays the checkered bar across the top like when you click on a project in the browser. In order to “wake” X back up, I have to click into the browser area (anywhere) and then back into the timeline window and now all is fine.
    This is intermittent and doesn’t happen every time I do it; however, it does happen multiple times as I work through the timeline. So it’s not an occasional, random thing. I have seen this behavior on more than one machine – old and new. And on dual and single screen configurations.
    FWIW – if I play and delete while playing on-the-fly this doesn’t happen. Only with a standard mark-in-out-delete procedure. Thoughts?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Oliver Peters replied 10 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
