Activity Forums DaVinci Resolve Playback speed is unstable with MC Color
  • Playback speed is unstable with MC Color
    Posted by Huang Di on October 24, 2011 at 5:49 pm
    Hi
    i have the MC color and the davinci 8.1 mac.
    if i play back the r3d in 1/4 few mins the play back speed will unstable which is like FF.
    But the playback speed is stability when I reopen the davinci without MC color.
    I try to reinstall all the soft and drivers,but the problem is stay.
    And I notice that the CPU is up to 60%-90% from 50% when the unstable is happen.
    But the speed is stability and the CPU is up to 85% when I play back the same r3d 1/4 with a lot nodes with out MC color .
    Which is the problem ?
    Sorry for my poor English.
    thanks
    Huang
    Kevin Cannon replied 14 years, 11 months ago 3 Members · 2 Replies
  • Jake Blackstone
    October 24, 2011 at 8:37 pm
    I use MC Color and I do not have this problem.
  • Kevin Cannon
    October 24, 2011 at 8:46 pm
    Possibly the Mac needs to use more CPU resources to use the MC Color interface, and that your CPU isn’t powerful enough to do 1/4 Res Red debayer and run the MC Color. Try 1/8th Res and see… Also a Red Rocket card would take a lot of the load off the CPU.
    I notice this occasionally when using RED footage, using the CPU to debayer, and drawing a lot of curve shapes in windows… I lose realtime playback not from too much GPU but too much CPU resources…
    KC
    Prehistoric Digital
    PhD Grading Suite
