Activity › Forums › Apple Final Cut Pro Legacy › playback speed between HDV and HD
  • playback speed between HDV and HD
    Posted by Marianne Souliez on October 4, 2010 at 3:06 pm
    Hello,
    I am editing 2 projects at the moment: one was shot on HDV (1440×1080), the other HD (1920×1080).
    I am baffled at the difference in playback speed between the 2 projects: the HDV one is perfectly smooth, both in the timeline and the canvas, but the HD one is a hastle: even moving frame by frame in a clip has a delays
    Is this normal or is therea hidden problem in my HD project?
    I have a Macbook Pro, Intel 2.2 GHz, RAM 4 Go
    Thank you!
    Shane Ross replied 15 years, 11 months ago 2 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    October 4, 2010 at 3:20 pm
    OK, HDV is a format, a specific format. Good. We got they. But “HD” isn’t specific. HDV is HD. Do what format of HD? ProRes? Uncompressed? H.264? Avchd?
    Shane
  • Marianne Souliez
    October 4, 2010 at 4:25 pm
    looks like I still have a lot to learn! 🙂
    the HD footage is H264, 1940×1080. Is that enough information?
    Marianne
  • Shane Ross
    October 4, 2010 at 4:31 pm
    Thank you. Perfect.
    H.264 is not an editing codec. You need to convert it to ProRes. And them edit in a prores sequence if you are going to mix editing both formats.
    Shane
  • Marianne Souliez
    October 5, 2010 at 10:23 am
    ok I am not planning to mix the two. Still, how do I convert the H264?
    thanks a lot!
    Marianne
  • Shane Ross
    October 5, 2010 at 1:39 pm
    Compressor. THere are settings for ProRes in there.
    Shane
  • Marianne Souliez
    October 5, 2010 at 5:41 pm
    ok cool thanks!
  • Marianne Souliez
    October 9, 2010 at 8:30 pm
    Hi Shane,
    because I am encountering another porblem on the same project, I thought I would ask you 🙂
    I have done the ProRes convertion; it helps indeed tremendously, phew!
    I only have one last problem: the cuts in the soundtracks each have an unpleasant glitch, like a tiny peak that goes “scratch”. Is it another format issue? That never happened on my HDV projects.
    Thank you for your help 🙂
    Marianne
  • Shane Ross
    October 10, 2010 at 10:32 pm
    [Marianne Souliez] ” the cuts in the soundtracks each have an unpleasant glitch, like a tiny peak that goes “scratch”. Is it another format issue?”
    Sometimes happens. Add a 2 frame dissolve to cover that.
    Shane
