Activity Forums Adobe Premiere Pro Playback problems
  • Playback problems
    Posted by Steven James on April 8, 2011 at 10:14 pm
    I’ve just switched from CS4 to CS5 and encountered a problem I haven’t seen yet. I’m far from a pro but I have been using the CS collection since CS3. Before I get started, I’m running 64-bit Win7. I have an AMD 3.0 gig quad core with 8 gig’s of ram. I’m working with AVCHD footage, but have never experienced a problem like this in the 3 years I’ve been editing AVCHD. I know you need a lot of horsepower for AVCHD and that’s hasn’t been a problem in the past.
    I recently had a problem with a video that I’m editing. The playback monitor won’t play anything when I play the timeline. The playback monitor is blank, but if I click on the monitor it will show the current frame. The frame shows the bulls-eye in the middle of the frame (like what you see manually position the frame instead of using the position controls in effects controls pane) and when I try to play the timeline it doesn’t go away and show the video like it normally would. The same frame stays there while the timeline plays. I’ve tried opening a new project and importing my sequences. That seemed for fix the problem, but it will occur soon after I start editing again. The timeline has been rendered out and green, so I know it’s not choking on the footage.
    I’ve worked with Premiere for about 3 years and can’t figure this one out. I feel like I must have done something silly and the fix is easily but just can figure it out.
    Anybody had this happen to them or have a fix for this?
    Steven James replied 15 years, 5 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    April 18, 2011 at 4:29 pm
    My first instinct is that the MPEG4 codecs weren’t properly installed. Did you install CS5 on top of CS4? Or did you remove CS4 first?
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Steven James
    April 18, 2011 at 8:22 pm
    Hey, Thanks Jeff.
    Boy, you nailed that one. Yes, I did install CS5 ontop of CS4 against my better judgement. I was in the middle of an editing job and thought since I had the room I’d do an install over CS4.
    I think I actually found the culprit. I’d recently installed the Neat Video plug in because some of my video was shot in low light. The plug in worked awesome but then I ran into those problems I described. After pulling the plug in out of the folder and reloading the project I got a warned about the missing plug in but everything else worked like normal again.
