Activity Forums Blackmagic Design playback monitor funniness…
  • playback monitor funniness…
    Posted by J. Tad newberry on January 10, 2007 at 9:36 pm
    in FCP, i pulled up an HDV1080i60 project and all is well except that it only outputs a still frame on my output monitor. the timeline plays smoothly in the canvas, but only puts out the still frame from wherever the cursor started. i can scrub through the timeline, and the output monitor scrubs as well, but still won’t play.
    i then pulled up my last NTSC-DV project, had the two of them side by side, and the DV project played fine on the monitor. i went back and forth between them to see what was different and couldn’t find any differences (thus far) in the settings. any idears??
    Kristian Lam replied 19 years, 3 months ago 2 Members · 3 Replies
  • J. Tad newberry
    January 10, 2007 at 11:28 pm
    someone provided me with the answer of checking my View>Video Playback setting that it should match my clips of HDV1080i…
    working great now, but it seems like that would’ve been part of the Easy Setup?
  • J. Tad newberry
    January 10, 2007 at 11:29 pm
    (by the way, my last question is really only addressed to the FCP crowd, not the BM crowd as Easy Setups are an FCP thing only…)
  • Kristian Lam
    January 11, 2007 at 11:09 pm
    Easy setups don’t follow your sequence so even if you switch timeline, it will still be set to whatever was last selected.
    regards
    Kristian Lam
    Blackmagic Design
