Activity › Forums › Apple Final Cut Pro Legacy › Playback Issues 1080HD From Canon 5D MKII
Dan Seibert replied 16 years, 5 months ago 10 Members · 18 Replies
John Fishback
March 22, 2010 at 7:58 pmGo down the page a little and enter Mac OS X and under Software you’ll see it.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Dennis Radeke
March 22, 2010 at 8:20 pmThere is no need for a plugin.
Premiere Pro CS4 can do it natively. If you need to convert the files, there are tutorials for how to batch process your original 5D footage into another codec using Adobe’s Media Encoder.
With the Mercury Playback Engine and native 64 bit in the future, the need for any kind of conversion will be unnecessary.
Hope this helps,
Dennis -
Robert Dix
March 22, 2010 at 9:15 pmShane,
FCP have just issued a patch to fix the problem with the 5D mark II
Australia
Robert Dix
March 23, 2010 at 12:47 amHi Dennis,
Have you got the address for the Tutorials to convert?
ThanksFreelance Imaging/Video
Retired (CPS Member)
Australia -
Robert Dix
March 23, 2010 at 12:48 amHi Dennis,
Australia -
Ben Holmes
March 23, 2010 at 11:58 amThanks Peter – hope you’re well.
Unfortunately the plug-in doesn’t support my 550D yet. And I did notice some ropey moments in a quick 720p50 test I did. It certainly lowers the quality from 1080p considerably.
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producerhttps://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Dennis Radeke
March 23, 2010 at 2:46 pmRobert,
Let me give you the steps and see if this helps. If not, I’ll either record a tutorial or search until I find the one I’m looking for… 😉
There are a couple of approaches including creating a watch folder, but I’ll give you instructions on how to convert a batch of files here.
1) launch AME (Adobe Media Encoder)
2) click Add
3) navigate to the files you wish to convert (shift select)
4) click okay when done
5) click Edit
6) choose your destination preset (I choose P2 Movie – Panasonic format that’s easy to edit but you may want something else if you’re using FCP)
7) Click okay to close
8) Click start QueueAME will work in the background, so you can be using other applications or tasks while it’s converting. Once done, import into Premiere Pro or FCP.
I hope this helps,
Dennisps – check out my tutorials at https://tv.adobe.com/show/adobe-beginner-classes-with-dennis-radeke/
