Activity › Forums › Panasonic Cameras › Playback issue?
  • Playback issue?
    Posted by Josh J. johnson on April 5, 2007 at 5:00 pm
    I’m not at home right now so I can’t check but I’m having kind of a strobe and maybe field render problem it seems on my footage. It appears like that in AE, in QT, and on DVD. Not quite sure if it looks like this on Avid will check. What would you guys suggest the problem is. I’m thinking my avid has the wrong setting I know its a 23.976 timeline but maybe I forgot to make it 2:3:3:2 or maybe it set it to render lower or upper field instead of field off.
    thanks.
    Josh J. johnson replied 19 years, 5 months ago 1 Member · 3 Replies
  • Josh J. johnson
    April 5, 2007 at 7:15 pm
    Stopped home for lunch my timeline setting was at standard pull down not advance so there is my issue. My question now is if I change the pull down to 2:3:3:2 will it work or do I have to change the pull down then recapture?
  • Josh J. johnson
    I shot 24pa.
  • Josh J. johnson
    April 9, 2007 at 1:51 pm
    Thanks David, I have it all figured out now!
