Activity Forums Adobe Premiere Pro Playback Issue
  • Playback Issue
    Posted by Aaron Cadieux on January 24, 2007 at 4:57 am
    I run Premier Pro 2.0 on a very fast dual core machine (4GB of RAM). For some reason, the desktop playback in Premier is very choppy (the playback on my preview monitor is flawless). I am assuming it is an issue with the video card. I have an Nvidia Quadro FX 1400 which (supposedly) is fully supported by the Adobe corporation. Anyone know of any fixes for this issue?
    -Aaron
    Harm Millaard replied 19 years, 7 months ago 3 Members · 10 Replies
  • 10 Replies
  • Harm Millaard
    January 24, 2007 at 11:07 am
    What is the source material (DV or HDV) and what is your disk setup?
  • Aaron Cadieux
    January 24, 2007 at 1:30 pm
    Just regular DV.
  • Harm Millaard
    January 24, 2007 at 2:09 pm
    and your disk setup?
  • Aaron Cadieux
    January 24, 2007 at 2:17 pm
    My C drive is my primary drive. I have two 300GB and one 150GB Seagates as my externals on firewire. I don’t have it set up as a RAID, because in my experience it is foolish for DV editing. I am just baffled… The computer is too state-of-the-art for these playback issues. I am guessing it is a setting somewhere.
    -Aaron
  • Harm Millaard
    January 24, 2007 at 2:48 pm
    Are the 3 fire wire disks daisy chained? Fire wire disks are not very fast to begin with, but if they are daisy chained you reduce the transfer rate even further. However, normally they should be fast enough to handle ordinary DV streams. Does rendering the time line help?
    Since your system is quite up to date, I would suggest you add an internal SATA disk. It is at least two times and possibly three times faster than the external ones.
  • Aaron Cadieux
    January 24, 2007 at 2:51 pm
    They are not daisy chained. Each drive has it’s own port on the firewire card. My primary internal drive is a 80GB seagate SATA. I guess I could do a test project on the primary drive and see if I have the same issue. By the way, you respond very quickly, and I appreciate it.
    -Aaron
  • Harm Millaard
    January 24, 2007 at 2:56 pm
    I assume your video driver is up to date, version 91.36?
    https://www.nvidia.com/object/winxp_2k_91.36
  • Aaron Cadieux
    January 24, 2007 at 3:51 pm
    I just updated it recently, but I am not at home, so I will have to check to see if I have the latest update later tonight.
  • Blast1
    January 24, 2007 at 9:17 pm
    [Cadge31] “Each drive has it’s own port on the firewire card”
    Some firewire cards only have one addressable port and two or three recept. acting as a hub for the single port and can cause problems.
    [Cadge31] ” My primary internal drive is a 80GB seagate SATA. I guess I could do a test project on the primary drive and see if I have the same issue.”
    If you are going to do a project on a system drive you could possibly end up with similar problem.
  • Harm Millaard
    January 25, 2007 at 10:32 am
    If you are interested what performance difference there is between internal SATA2, external eSATA2 and USB2 external disks, look here: https://www.asrock.com/news/eSATAII.asp
