Activity Forums Adobe Premiere Pro Playback is fine in source monitor, but slow in the program monitor
  • Playback is fine in source monitor, but slow in the program monitor
    Posted by Chris Farrington on October 22, 2021 at 11:28 pm
    I recorded footage on a RED at 6K. I imported the footage with the “scale to frame size” option selected. When I watch the footage in the source monitor at 1/4 resolution, it plays back smoothly. No lag. I then created a new sequence with the ARRI 1080p settings. I dragged the source monitor footage into the sequence. Premiere said the footage didn’t match, and did I want to change the sequence to match the footage. I tried both the “yes” and the “no, ” but no matter what I choose, the program monitor is incredibly laggy, even at 1/8th resolution. It seems like it’s not a processing issue if it can play the source content just fine. Working on a Macbook pro, 11.5.2 OS, Premiere 15.4.1.
    Chris Farrington replied 4 years, 10 months ago 2 Members · 3 Replies
  • Bret Hampton
    October 23, 2021 at 12:38 am
    Chris
    More details are helpful, like how much ram, drive size, type, etc.
    I suspect you’re underpowered as set up. One alternative is create proxies as you seem to be in 6k which is a lot for a laptop to handle.
    I don’t use Mac to edit, so I suggest you join our Facebook Premiere group. Lots of pros there on Macs. Ask for Kyle.
    https://www.facebook.com/groups/524598280935129
    Bret
  • Chris Farrington
    October 23, 2021 at 12:46 am
    Hi Bret,
    Thank you for the reply. I guess my question is, why would those hardware specs matter if my computer has shown it can easily play the footage? Why would the program monitor be different than the source monitor?
    Chris
  • Chris Farrington
    October 25, 2021 at 6:18 pm
    I’ve tried every possible sequence setting that should make this work. So confused. How is the source monitor playback processing different than the program one if the footage and the sequence have the same setting?
