Activity Forums Panasonic Cameras Playback from FS100
  • Playback from FS100
    Posted by Terry Moore on March 14, 2007 at 4:35 pm
    I am using a Panasonic HVX-200 and am having trouble playing back footage recorded on the FS100. How do I tell the camera to look at the Firestore instead of the P2 card or tape for playback?
    -Logan
    Terry Moore replied 19 years, 5 months ago 2 Members · 2 Replies
  • Tony Cope
    March 14, 2007 at 5:06 pm
    When you switch your camera to the PLAYBACK mode – you will initially get the thumbnail viewer (for footage on the P2 card.) Push the button on top of the camera marked THUMBNAIL – and you will get a solid blue screen. Then press play on your Firestore drive, and it will playback the footage. One thing to keep in mind – you can only playback footage matching the P2/tape setting on the camera. If you recorded 480i DV (tape mode) you need to be in that setting to view the clip. The same goes for footage shot in the p2 mode.
    Good luck,
    T
  • Terry Moore
    March 14, 2007 at 7:49 pm
    Thanks! It worked.
