Activity › Forums › Apple Final Cut Pro Legacy › Playback after Compression
  • Playback after Compression
    Posted by Helena Kristen guenzel on March 18, 2009 at 3:24 pm
    I have a random question….
    Why is the playback of a project after it’s been sent to compression and burned to a DVD faster than when it’s being edited and played in Final Cut pro.
    Is there a way to “slow down” the playback speed so that it doesn’t seem sooo fast when watching the final project?
    Michael Sacci replied 17 years, 6 months ago 2 Members · 3 Replies
  • Michael Sacci
    March 18, 2009 at 4:13 pm
    sounds like you have retimed the encoded footage, this is not a normal thing, there is a setting that is wrong. There is a frames tab in compressor and retiming is on the bottom, have you set anything there?
  • Helena Kristen guenzel
    March 18, 2009 at 5:43 pm
    When I go to the inspector, here are the “current” settings for either Best Quality or Fastest Encoding:
    Frame Controls: off
    Resize Filter: Better (Linear Filter)
    Output Field: Same as Source
    Deinterlace: Fast (Line Averaging)
    Adaptive Details : checked
    Anti-alias: all the way to the left
    Details Level: all the way to the left
    Rate Conversion: Fast (Nearest Frame)
    Set Duration to: 100%
    The film was shot at 23.98.
  • Michael Sacci
    March 19, 2009 at 7:21 am
    this is an odd one, if the Frame Controls is off, everything else should be grayed out.
    Would have to see the project to figure this one out.
