Activity › Forums › Adobe Premiere Pro › play monitor behavior in Premiere 2017?
  • play monitor behavior in Premiere 2017?
    Posted by Paul Dougherty on July 13, 2017 at 2:42 pm
    In Premiere 2017 why does the Play button default to playing what is marked instead of playing from where the playhead is parked?
    Paul
    Todd Perchert replied 9 years, 2 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    July 13, 2017 at 3:08 pm
    Is it the play-button or the play in to out-button?
  • Paul Dougherty
    July 13, 2017 at 3:55 pm
    the regular play button as well as the space bar. If the playhead is parked before the In mark, it jumps to play from the IN (bad) However if the playhead is parked between the In & Out – it will play from that point on (correctly). strange
  • Todd Perchert
    July 13, 2017 at 6:35 pm
    Sounds like something got remapped or you may need to restore your preferences.
    To restore default preference settings and plug-in cache at the same time, hold down Shift-Alt (Windows) or Shift-Option (Mac OS) while the application is starting. Release the Shift-Alt keys or Shift-Option key when the splash screen appears.
    https://helpx.adobe.com/premiere-pro/using/preferences.html
    Good Luck!
    TC
