Activity Forums Adobe Encore DVD Play button to animate dvd menu
  • Play button to animate dvd menu
    Posted by Todd Johnson on July 18, 2008 at 3:28 am
    I want to make a dvd menu where after you press the play button there would be a small animation. it would only be about 3 seconds at most. it would just be an additional layer. For example: picture has a guy with two fists in the air, when the play button is hit, i want two things to appear in his hand and something to pop out from the right side of the menu. Is this making sense? sorry if it’s confusing.
    Todd Johnson replied 18 years, 1 month ago 2 Members · 2 Replies
  • John Rich
    July 18, 2008 at 4:13 pm
    You could try using a “button Transition” using the menu as a background and making the rest of your animation in After Effects.
    John
    JOHNR
  • Todd Johnson
    July 18, 2008 at 9:24 pm
    ok, i’ll try this. thanks for the help john.
