Activity Forums DaVinci Resolve Play Back Flashing
  • Play Back Flashing
    Posted by Stephen Wiley on October 11, 2011 at 1:19 am
    Hi:
    DaVinci newb here, encountering two odd behaviors after install of cards and software.
    Sometimes upon booting up DaVinci, a warning window appears saying it can’t find the
    CUDA drivers, which are installed and working on the previous session. I have to reinstall
    the drivers and reboot the computer. Also, when I’ve used a power window on a grade,
    the Viewer starts flashing during playback, effecting the other graded clips as well. If
    I restart DaVinci, it’s fine until the next time I lay in a power window. Any clues or direction
    to find a solution would be appreciated.
    The system is a 8 core, 4,1 mac pro with 12 gigs ram, 5770 GUI board, 4000 GPU
    board and Decklink extreme 3D with Tangent Wave.
    Again, thanks for any input.
    Rohit Gupta replied 14 years, 11 months ago 3 Members · 3 Replies
  • Peter Chamberlain
    October 11, 2011 at 4:51 am
    Hi, you haven’t mentioned which version you have? Is the issue one one window type or all?
    Do you ever see the flashing if there are no windows?
    This is sometimes caused by the system if it can’t find the dongle so be sure that its plugged directly into the Mac chassis. If the problem persists, please capture your logs and system config and email to davincihelp@blackmagic-design.com so the guys can have a look.
    thanks
  • Stephen Wiley
    October 11, 2011 at 6:35 am
    I’m running V.8. It seems to happen with all types of power windows,
    though I like to use the circular window the most. Thanks for your input.
  • Rohit Gupta
    October 11, 2011 at 8:05 am
    Please capture your logs and system config and email to davincihelp@blackmagic-design.com
    You can capture the logs using the CaptureLogs.app at:
    /Library/Application Support/Blackmagic Design/DaVinci Resolve/CaptureLogs.app
