Activity Forums Avid Media Composer Play around trim point monitor only outgoing/incoming
  • Play around trim point monitor only outgoing/incoming
    Posted by Matthew Bradshaw on February 4, 2011 at 9:55 pm
    Hi, coming back to Avid after a while away … Is there a way to monitor only the outgoing or incoming audio at a trim point so that I can check whether spurious audio is on the outgoing or incoming shot? I seem to remember I had a short cut for this years ago but have forgotten it.
    Many thanks, Matt.
    Matthew Bradshaw replied 15 years, 7 months ago 2 Members · 3 Replies
  • Matthew Bradshaw
    February 4, 2011 at 11:12 pm
    Ok … making 2 trim settings with 0 for pre-roll or post roll seems to work. Is that the best/only way and can I assign settings to a key or button?
    Many thanks, Matt.
  • Jeff Greenberg
    February 5, 2011 at 4:14 pm
    Yup. In trim mode while the footage is playing tap Q (go to in) or W(go to out). The system will now loop the outgoing only or incoming only. Very powerful.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Matthew Bradshaw
    February 5, 2011 at 5:15 pm
    Many thanks Jeff. That is just what I wanted to know. I was hitting Ctrl Q/W because my muscle memory took me there.
    Thanks again, Matt.
