Activity Forums Adobe Encore DVD play all/ chapters
  • play all/ chapters
    Posted by Roen Davis on July 4, 2007 at 2:45 am
    Hello all!
    i have looked through help and manuals and even got some advice for a similar issue here – but it still polagues me.
    So i need a play all and a chapters select. i went through and set the chapter markers and set end action for each one but the play all button now executes the chapter end action – this was for both simple chapter markers and after setting up a chapter playlist.
    do i need overides or am i missing something?
    cheers roen
    Roen Davis replied 19 years, 2 months ago 2 Members · 2 Replies
  • George Wing
    July 4, 2007 at 10:54 am
    Instead of using Chapter END-ACTIONS or Overrides, I would setup some Chapter Playlists. Then link to the Chapter Playlist when you only want a single chapter (or several chapters that you can add to a Chapter Playlist).
    This should work (unless you have more than ~18 Chapter Playlists).
    Regards,
    George
  • Roen Davis
    July 4, 2007 at 11:01 pm
    Thanx George W – i will put that into action!
