Activity Forums Adobe Encore DVD play all button failure
  • play all button failure
    Posted by Audiovisualist on November 4, 2005 at 10:11 am
    hi, my problem is that i create a play all button with 3 timelines, everything is ok but the last clip plays 2 times and then he move to the main menue? why does it loop?
    Audiovisualist replied 20 years, 10 months ago 2 Members · 2 Replies
  • David Garrett
    November 4, 2005 at 10:39 am
    re-check all links again…
    should be like this.. “PLAY ALL” button’s end action to play timeline 1- it’s end action to play timeline 2- it’s end action to play timeline 3- it’s end action to go back to menu.
    click on each timeline in turn and check that the end actions are set up properly, or if you have Encore 1.5 then create a playlist for all timelines and then set the “PLAY ALL” button to link to this playlist with the end action set to return to menu
  • Audiovisualist
    November 4, 2005 at 10:47 am
    thanks for your fast reply, i have found the problem it was an override problem, thanks now it works fine.
