Activity Forums Adobe After Effects Platinum in CS5
  • Tudor “ted” jelescu
    June 22, 2010 at 10:49 pm
    Kinda hard to understand your problem from the way you used english.
    My guess is that you are trying to use a plugin that was designed for CS4 in CS5- it will not work since CS5 is running on 64bit. You need the updated version of the plugin- check with the plugin developer for upgrades.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
