Activity Forums Apple Final Cut Pro Legacy Plaese VOB File Help with FCP 7 and breaking the Audo into 2 channels if possible?
  • Plaese VOB File Help with FCP 7 and breaking the Audo into 2 channels if possible?
    Posted by Paul Roubicek on September 24, 2010 at 9:27 am
    Hi I know this has been talked about many times on the forums l have look at them but l need a little extra help please with the VOB files l have
    1.l have only the DVD’s and also the VOB files l have taken from the DVD’s to use no other footage or the original footage its all l have
    question.
    l want to make a show reel from these files with FCP 7 what is the best quick-time conversion to no lose any more quality?
    2. l have been trying Motion apple A (is this OK to edit with) interlace and also deinterlace and they both look OK, l have tired uncompressed 8 and 10 bit and all the other mentioned solutions l have seen on this site none are any good lose to much and also get interlacing a lot.
    can some one tell me if the apple A is OK to use for edit? if not whats better to keep the VOB as it is.
    L get so much interlacing when the Motion Apple A is on the time line not when just paying out of time line???
    how Do l get ride of the interlacing
    and for output to use as a email file and also linked file for people to see whats the best output compression, information
    if l want to have the 2 channels of audio so no voice over and only Nat is there a way??? and if so what program to do it
    and last Does the Quick time MPeg-2 playback work on FCP 7 and will it give Video and Audio????? for direct FCP editing with VOB files
    hope someone can help , please
    cheer and thanks Paul
    Paul Roubicek replied 15 years, 11 months ago 3 Members · 5 Replies
  • Sean Kapleton
    September 24, 2010 at 9:46 am
    open with mpegstreamclip and export as needed
  • Paul Roubicek
    September 24, 2010 at 10:07 am
    Hi whats the best export to use everything think have tired looks not great??? l just need it for show reel but looking good.
    also what’s the best Time line to work in with this
    and how do l get ride o the interlacing really bad
    and is there a way to get the 2 audio channels by them self’s as l would prefer the Nat sound not Voice over
    thanks Paul
  • Brad Elliott
    September 24, 2010 at 7:56 pm
    Do the showreel settings and your VOB match?
    Is the footage SD/HD? 4×3 SD DVDs are 720×480. 16×9 is 853×480.
    What export codec are you using? ProRes 422 would be a good place to start.
    If the audio is mixed there is no simple answer for separating the VO from the other audio elements. EQ in Soundtrack Pro or Ableton Live would be a possible but not simple options.
  • Brad Elliott
    September 24, 2010 at 8:23 pm
    Agreed.
    But Streamclip does have a 854×480 export option if you drop in a SD 16×9 VOB.
  • Paul Roubicek
    September 25, 2010 at 3:13 am
    Thanks for that information, sorry for late reply’s to my question time difference, please let me fill you in on the footage.
    the problems l am having is the footage which l filmed was from 2 camera’s, either HDV1080i Sony FX1 or Panasonic HDV 1080i full size camera. all NTSC Cameras
    the Edits where done in the states but not by me, l have tired to get hold of them, to find out the editing information Don’t think l will be able to, so l am unsure other than a HDV capture from there ???? ( unsure of there time line?)
    the Company that sent me the DVD’s was USA Company HDNet if any help
    the DVD’s l have already have had TS.VOB files made and are
    on my Hard drive but l also have the DVD’s as well for use.
    the information of VOB files are
    originally filmed on Sony HDV-FX1 1080i
    VOB stream information Original Edit time line UNSURE
    Video
    224 MPEG-2, 720×480, 4;3 29.97fps 8.82Mbs, upper field first
    Audio
    128ACS 2/0, 48KHz, 384Kbs
    originally filmed on Panasonic HDV1080i Full size camera
    VOB stream information Original edit time line UNSURE
    video
    224 MPEG-2, 720×480, 4;3 29.97fps 4.62Kbs upper field first
    Audio
    Audio
    128ACS 2/0, 48KHz, 256Kbs
    near all the VOB files are this way in VOB stream infornation give or take a few frames Differences
    So from what l have available to use at this stage is only the DVD’s and the VOB files l have already made from the DVD’s , from this l want to make a show reels of the the Footage and also have available web links to this footage on my web site, and if need be, Be able to send as DVD (if quality will be OK)
    Questions.
    1. l have tired the Proress 422 hq and also normal but still get interlacing in the time line l have tried 8 and 10Bit., Whats the best way out of the VOB file for me for my use and finished edit compression once l have edited.
    1a Whats the best FCP7 Time line setting to work in with all of this.
    1b Whats the best web format to put the finished Edit into for a web link and use on my web site???
    2. whats the best format to be able to send a 3 to 4 minute clip via email ( after edit)
    4. how do l get ride the interlacing?
    5. Audio tells me 2 channels if there a way out to get either the VO or Nat sound only
    6 is it bad to edit with the VOB straight in to FCP 7?
    thanks for your time guys hope to back from you and the information can be of assistance with my questions l have about 40 Documentaries l want to edit through.
    Paul
