Activity › Forums › Maxon Cinema 4D › Placing objects from imported coordinates
  • Placing objects from imported coordinates
    Posted by Graham Lingley on July 9, 2010 at 9:24 am
    I have some coordinates from a excel/csv file and I wish to place a sphere at each coordinate. I can import the data into a polygon object as a bunch of points but can get no further. It sounds relatively simple, but I am no expert in C4D.
    Graham.
    Graham Lingley replied 16 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 9, 2010 at 5:47 pm
    if you have MoGraph you can do it with a Cloner Object set to Object mode and use your points object as the Object. If not, there pre-MoGraph there were numerous plugins that did the same thing, it should also be possible to do the same thing via XPresso
  • Graham Lingley
    July 12, 2010 at 12:03 pm
    Thanks Brian. I knew I was missing something fundamental!
