Activity Forums Apple Final Cut Pro Legacy Pixels in Final Cut with Red Colors?
  • Pixels in Final Cut with Red Colors?
    Posted by Bengalland on August 31, 2006 at 4:31 am
    My footage shot on the Panasonic DVX 100B it totally pixeled on the colors RED. Everything else of all other colors looks fine but the reds are really bad. I used the easy set up with my Final Cut 5 system on my G5 Dual 2 Ghz. system and set it up to capture DV NTSC Anamorphic. 29.97. Pretty standard issue stuff but i have never seen this. I am also using a Firewire LeCei Drive and a G-Raid drive??? Got any advice??
    Andrei Bocharnikov replied 20 years ago 3 Members · 2 Replies
  • David Roth weiss
    August 31, 2006 at 5:05 am
    Ben,
    The DV codec just sucks the heck right out of red and adds horrendous artifacts too. I had abeautiful high rez still of a book cover with red titles that looked like complete garbage after rendering to DV. Later, after uprezing the entire project to 10-bit the book cover was flawless.
    DRW
  • Andrei Bocharnikov
    August 31, 2006 at 8:32 am
    Ben, i have the same problem even with my HD camera HVX200. Check the thread on the link below, i hope it will give you some information about what is going on.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=193&postid=861433&pview=t#head
    Andrew
