Activity Forums Adobe After Effects Pixellation problem
  • Pixellation problem
    Posted by Kfilmo on August 9, 2005 at 5:30 am
    Have successfully completed several effects but all have pixellation. We set up Comp to Best and to NTSC.
    System: AE 5.5.1, Mac G4, OS9.1, 704 MB memory.
    processor speed: 400 Mh. Kindly help.
    Kfilmo replied 21 years ago 2 Members · 2 Replies
  • Barend Onneweer
    August 9, 2005 at 2:37 pm
    At what stage are you seeing the pixellation?
    Can you see it in the comp window? Or is it introduced in the render. Are you rendering to a compressed format? If you’re rendering to DV, you may well be seeing the 4:1:1 downsampling of chroma in the DV codec.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Kfilmo
    August 11, 2005 at 9:48 pm
    Pix occurs in the Comp window as soon as I set keyframes.
    Good images in AE render out nicely to our editor.
    Frank
