Activity Forums Apple Final Cut Pro Legacy Pixellation Issues in Converting 720p to 1080p ?
  • Pixellation Issues in Converting 720p to 1080p ?
    Posted by Rajarshi Basu on February 8, 2008 at 2:52 pm
    hi,
    On converting HDV 720p to 1080p using Compressor…the image is looking alright on the computer monitor.
    But I need to show the film on a large screen for theatrical.
    Will the pixels show up… or the image quality suffer noticeably on a larger display ?
    What about Instant HD plugin ??
    Raj
    Chris Poisson replied 18 years, 7 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    February 8, 2008 at 4:16 pm
    Have you tried it?
  • Rajarshi Basu
    February 8, 2008 at 4:37 pm
    No…I’m downloading the trial version and checking …
    but logically 720 is 720*1280
    and 1080 is 1080*1920
    so changing from 720p to 1080p is going to induce pixellation, how is Compressor going to change that ??
    Raj
  • Jeremy Garchow
    February 8, 2008 at 4:45 pm
    [Rajarshi Basu] “so changing from 720p to 1080p is going to induce pixellation, how is Compressor going to change that ?? “
    Have you tried doing the conversion in Compressor yet?
    Have you tried taking your 720p timeline, putting in a 1080 timeline, scaling and render?
    You are not upconverting, you are cross converting. It’s a much better process than going sd to hd.
    Jeremy
  • Chris Poisson
    February 8, 2008 at 6:02 pm
    Compressor can do the cross-conversion just fine, but you should do some short tests, and you should view on at least a 23″ Apple Cinema Display with your video output set to “Cinema display full screen”
    An MXO or a real HD monitor would be even better.
    When you do your Compressor tests, turn on the frame controls and boost antialiasing to say 50 or so. It will take a lot longer but it works fine.
    Have a wonderful day.
