Activity Forums Apple Final Cut Pro Legacy Pixellated transitions in an export QT
  • Pixellated transitions in an export QT
    Posted by Brent Stanley on February 12, 2010 at 4:44 pm
    Hoping someone else might have run into this…
    We’re running two edit suites, both running FCP 6.06. Both suites have Quad core dual 2.8’s with 8 GB’s of ram.
    We’ve been delivering shows all year to our client, editing in a 1080p timeline, and then converting to a XDCAM 1080i60 VBR setting on export.
    17 shows and not a hitch. We’re shooting video onto a Nano card, and importing .mov files straight into FCP.
    Yesterday we created a QT for a new show, out of our second suite. Same settings. Now the odd thing that’s been happening in that suite, is during ‘Render All’ it’ll pop up with a message saying ‘conforming MPEG 2 video,’ and the renders take a real long time.
    At any rate, during a quality control check last night we discovered that about 70% of any effects (dissolves, wipes, resizing of windows in split screens) there’s pixellation (best I can describe it)
    We haven’t had this issue at all, all year long, out of our main edit suite. I suspect we’ve got some kind of issue with settings in our second suite, but I can’t seem to find it.
    Anyone have any suggestions?
    Chris Borjis replied 16 years, 6 months ago 2 Members · 3 Replies
  • Chris Borjis
    February 12, 2010 at 5:21 pm
    that conform mpeg message usually comes up with HDV and I have seen it happen with xdcam.
    on any xdcam projects I do, I change the compressor in the sequence settings to prores
    just before I color correct and export the file.
    that might help you.
  • Brent Stanley
    February 12, 2010 at 6:05 pm
    So when you say pro-res, you mean make it XD cam? My other editor just finished doing just that, and we did a short test QT, and the issue seems to have cleared up.
    But I wasn’t sure if I should be using an Apple pro-res setting – that doesn’t seem to be a choice available in the settings pulldown.
  • Chris Borjis
    February 12, 2010 at 11:47 pm
    in the sequence settings, somewhere there is an option to change the
    compressor from xdcam to prores.
    change it prores. then render out your timeline.
