Activity Forums Adobe After Effects pixelation in my NLE
  • pixelation in my NLE
    Posted by Lee Peeler on May 23, 2005 at 10:27 pm
    I am trying to get jobs I do in AE into my Discreet Edit NLE. I have put the render settings on “best” and “full” and to my knowledge doing the right things, but when I import the job into Discreet the AVI video comes out pixelated on my monitor. Any suggestions?
    Chris Smith replied 21 years, 3 months ago 3 Members · 4 Replies
  • Chris Smith
    May 23, 2005 at 11:20 pm
    Just to clear the obvious: Your render resolution is the same as your timeline resolution in your NLE, yes? You are using an uncompressed codec?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Visual_guy
    May 24, 2005 at 2:52 pm
    I’ve never had much luck with AVI’s. It’s not exactly an industry standard
    format for graphics, although 3D guys tend to show up with them more often
    for some reason. Most editors are going to ask for Quicktime in the Animation
    codec. Make sure that your Field Render is set to “Lower”. This is the proper
    field order for most NTSC interlaced projects.
    Also, the Discreet folks we deal with usually want a Targa sequence rather
    than a Quicktime file, but I believe the latest versions of Discreet (sorry – Autodesk)
    software allow you to import Quicktimes.
    Brett
  • Lee Peeler
    May 24, 2005 at 9:49 pm
    My NLE is Discreet Edit and the native codec for it is Matrox Digisuite Motion JPEG. On my previous attempts I was using another codec. The Motion JPEG allows Discreet to work with After Effects resulting in the correct image quality. Thanks Chris, if you read this.
  • Chris Smith
    May 24, 2005 at 9:54 pm
    Cool. I would still use Quicktime with an uncompressed codec though instead of something compressed like Jpeg.
    Chris Smith
