Activity Forums Apple Final Cut Pro Legacy Pixelated text in FCP 7 timeline using FCP Lower 3rd text tool
  • Pixelated text in FCP 7 timeline using FCP Lower 3rd text tool
    Posted by Laurie Patton on September 12, 2011 at 2:45 am
    Working in Final Cut Pro 7
    I am working in a timeline where I have converted to 4:3 from 3:2. This project is using both DV and mini DV footage.
    (Final Cut Changed the timeline to 3:2 when I put the DV video in the timeline.)
    All of my Lower 3rds are pixelated. I created these lower thirds in FCP. At first I thought it was because I had cut and pasted from another timeline. But, even if I create a new lower third in this timeline, it is still pixelated. It looks great BEFORE it is rendered and then after it is rendered, bad.
    While I understand the basic premise of why it is happening. I need to know how to fix it ASAP please. Thank you
    Frame size: 640×480 NTSC 4:3
    Pixels Aspect Ratio:NTSC-CCIR 601/(DV 720X480)
    Mac OS X 10.6.7
    8GB
    Processor 2.2GHZ Intel Core i7
    Michael Gissing replied 14 years, 12 months ago 2 Members · 1 Reply
  • Michael Gissing
    September 12, 2011 at 6:47 am
    This is a standard problem in DV timelines. Copy the final sequence into a new sequence set to ProRes 422 and then render. Everything, particularly graphics and text will look as sharp as SD can.
