Activity Forums Adobe After Effects Pixelated PSD files
  • Pixelated PSD files
    Posted by Richard Lutz on February 27, 2012 at 4:46 am
    I’m working on a animation using a lot of PSD files. I’m working with another designer who is building things and then sending them to me.
    I just looked at his settings and they are CMYK and 300 DPI. After converting to RGB I tried importing things but I feel like I’m losing my image quality in the process. Everything just seems pixelated. Why would this be?
    Walter Soyka replied 14 years, 2 months ago 2 Members · 1 Reply
  • Walter Soyka
    February 27, 2012 at 10:40 am
    [Richard Lutz] “I just looked at his settings and they are CMYK and 300 DPI. After converting to RGB I tried importing things but I feel like I’m losing my image quality in the process. Everything just seems pixelated.”
    DPI doesn’t matter to AE — pixels do.
    DPI is dots per inch. You can have a 300 DPI image, but if it’s only one inch square, it’s only 300 by 300 pixels and won’t look good stretched to full screen in a standard definition comp, let alone a high-def comp. Contrariwise, a 72 DPI image that 36×24 inches wide would yield 2,592×1,728 — plenty big enough.
    AE tells you the resolution of the image in the project panel — just select one of the images and look next to the thumbnail.
    Other possible culprits: draft mode in AE or pixel aspect ratio correction (which looks jagged in the viewer, but actually renders cleanly).
    Walter Soyka
