Activity › Forums › Boris FX Particle Illusion › Pixel size
Pixel size
Posted by Paul Hansen on July 2, 2007 at 4:51 pmI have looked in the FAQs and haven’t found the answer I need. Let’s say I make a circle emitter and then save it as an AVI file. When I import it into Premiere, it is no longer a circle but rather an oval. Is there a way to correct this?
Dnavarrojr replied 19 years, 2 months ago 3 Members · 6 Replies -
Elvis Deane
July 3, 2007 at 7:36 pmCould be that the pixel aspect ratio of your Premiere project is set to 0.9 by default, and pI’s stuff is square pixel. Don’t have Premiere here to check that, but that’d be my guess.
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
Wilbur of Wumbaberry -
Elvis Deane
July 4, 2007 at 8:10 amIt depends on your output. If you’re going out to videotape/DVD, you’ll want to keep it 0.9 since that will look oval as you work in Premiere, but should play right on a TV. If you’re going out to the web, then a 1.0 pixel aspect ratio is a better bet.
Elvis Deane!
Elvis Deane
July 8, 2007 at 4:45 amNope, it’s only square pixel at this point.
Elvis Deane!
Dnavarrojr
July 22, 2007 at 11:52 amOne thing you might try is output to 640×480 from PI then “stretch” it to 720×480 to fit the full frame. This will distort your circle into an oval, but when viewed on TV it looks like a circle.
