Activity › Forums › Apple Final Cut Pro Legacy › pixel dropouts when rendering at DV resolution
  • pixel dropouts when rendering at DV resolution
    Posted by Spotnik on March 23, 2007 at 11:17 pm
    Anyone else notice pixel dropouts when rendering at DV resolution?
    This usually happens with a color correction or other filter.
    It looks like random black squares. If I re-render they appear
    in different places. This happens also when exporting out of Motion.
    Other resolutions don’t have this problem.
    I’m using Quicktime 7.1.3, Final Cut Pro 5.1.2,Compressor 2.3,
    OSX 10.4.8, Dual 2.5 ghz PowerPC G5
    Samantha Nell replied 17 years, 9 months ago 3 Members · 3 Replies
  • Jeff Coleman
    March 24, 2007 at 1:24 pm
    I haven’t noticed.
    What filters exactly seem to be causing this problem?
    Have you tried changing your Sequence Settings/Video Processing tab to see if the problem changes?
    Love,
    Jeff
    Final Cut Studio 5.1, G5 2GHz Dual Processr, 2.5Gb RAM, AJA IO
  • Spotnik
    March 25, 2007 at 5:54 pm
    Since this also happens outside of Final Cut (Motion exports in DV),
    I suspect a flawed version of Quicktime or perhaps more ominously,
    a hardware (RAM?) issue. The problem has persisted since a clean
    re-install of OSX and all other applications.
  • Samantha Nell
    December 17, 2008 at 4:18 pm
    Hey Spotnik
    I have the same problem. Did you ever manage to solve it? And how?
