Activity › Forums › Adobe After Effects › Pixel Aspect Ration for HDV from FCP 5 to AE
  • Pixel Aspect Ration for HDV from FCP 5 to AE
    Posted by Seaton Lin on June 8, 2005 at 9:43 am
    Hello.
    I recently shot some footage using the new HDV format. Quicktime says that my footage is 1920X1080. When I import the footage into FCP 5, it interprets the footage at 1440X1080.
    Now if I were to export the footage from FCP 5 to AE and use for compositing, should I export my footage at 1440X1080 and set up my AE comps subesquently, or should i render out my edit from FCP 5 at 1920X1080?
    Is this a square pixel issue similar to that of SD: 720X540 = 720X486?
    Help… thank you very much.
    Mark Cookman replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mark Cookman
    June 8, 2005 at 10:41 am
    Ric Gerrad gave me this advice it worked well for me :
    HD and HDV are all square pixels. 1440 X 1080 is exactly 16:9 with 1.33PAR. If you are going back out to HDV 1080 then that is the size for your final render comp. For now it will be best to interpret the footage as square pixels and just work in that sized comp unless you have other output options.
    If you are outputting to DV PAL widescreen or outputting HD at 1920 X 1080 then you fit the footage horizontally by using the shortcut Cmnd/Ctrl + Option/Alt + Shift + h. with the footage interpreted as square pixels.
    The other option you have is to multiply the X scale by 1.33333 for a 1920 X 1080 comp (You’ll see 133.333% for the X scale if you fit the footage horizontally using the shortcut).
    If you want to use this footage in a PAL widescreen comp then fit the footage to the comp using the Ctrl/Cmnd + Alt/Option + Shift + F shortcut interpreting the footage as square pixels. That should give you X and Y scales of 71.111% and 53.333.
