Activity Forums Adobe After Effects Pixel Aspect Ratio Help
  • Pixel Aspect Ratio Help
    Posted by Mario Golfari on December 30, 2008 at 10:06 pm
    I rendered a quicktime clip from After Effects with the following configurations:
    NTSC DV (720×480)
    D1/DV NTSC (0,9)
    29,97
    I imported the clip into a final cut projet and I placed it into a compatible sequence (the settings done auitomatically):
    NTSC DV (3:2)
    CCIR 601/ DV (720X480)
    The image I see in the Final Cut viewer and canvas is squashed (things look thinner). The clip exported from this sequence looks fine, I was wondering if i´m doing something wrong.
    Richard Harrington replied 17 years, 8 months ago 2 Members · 3 Replies
  • Richard Harrington
    December 31, 2008 at 5:43 am
    Use the AE preset for NTSC DV and you’ll be fine in FCP
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Mario Golfari
    December 31, 2008 at 1:32 pm
    I am using the NTSC DV preset on AE and I see the image in the final cut visializer and canvas squashed. Is this supposed to happen? Because [even though the render out of FC looks ok]it is a bit distracting to edit and visualize the work when it is squashed (I´m working with graphic animation).
    December 31, 2008 at 3:20 pm
    Click view menu in FCP browser and canvas and make sure Pixel Aspect Ratio correction is o n
