Activity Forums Boris FX Particle Illusion Pixel Aspect Ratio composite issue???
  • Pixel Aspect Ratio composite issue???
    Posted by Mark Weaver on November 7, 2008 at 9:55 pm
    Hello all,
    Ran into a problem with PI. I am trying to composite Meteor from
    PI into AE over my background video. The backgroud video was taken
    with an HVX200 so the resolution is 960×720 PAR=1.333.
    The default setup for compositions in P2 format is with the PAR
    set to 1.33, however I can’t seem to find the option to set this in
    PI. I can create 1280×720 square pixel out of PI, but when this
    gets put into the default AE comp(1.33) the alpha channel just
    gets messed up. Blocky edges… I’ve been through the tutorials
    and tried all the options… The luminescent premultiply is the
    way to go, but the alphas still get messed up.
    As a test, I changed the AE comp to 1280×720 PAR=1 and put the
    same two files in it… WOW wonderful composite!!!!
    Because all my footage is HVX200 stuff is there a way to set the
    PAR in PI to 1.33 so I can just use the defaults in AE.
    Okay this was long winded… Sorry about that…
    MBW
    Mark Weaver replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
