Activity › Forums › Adobe After Effects › Pixel aspect ratio.. basic
  • Pixel aspect ratio.. basic
    Posted by Leon Klein on May 25, 2007 at 5:43 am
    Hello
    Does the toggle pixel aspect radio correction botton is just to see how the comp its going to look on a TV?
    If I import images or video to my comp and they look wider in my comp.. would they look like that when i export it into any format to be looked in a computer?
    thanks
    leo.
    Steve Roberts replied 19 years, 4 months ago 2 Members · 3 Replies
  • Steve Roberts
    May 25, 2007 at 12:09 pm
    Yep. If it looks wide on your computer monitor, it’ll look wide on anyone’s computer monitor.
  • Leon Klein
    May 26, 2007 at 4:26 am
    thanks..
    so.. if i made a video than i want to use for both TV and WEB, what should i do?
    export one of them with the toggle pixel aspect ratio on? is there an render option with to do this…
    thanks again.
    leo
  • Steve Roberts
    May 28, 2007 at 3:36 pm
    Assuming you’re in NTSC-land:
    1- work in a 720×540 square pixel comp (use the preset)
    2- use Composition>Make Movie. Set the Output Module (OM) to stretch your comp to D1. If you want to render to DV, stretch to D1 and crop pixels 2 off top, 4 off bottom to make 480. This is your TV render. Make sure you are not rendering fields.
    3- use Composition>add Output Module. Set this OM to stetch to 320×240 or whatever.
    This way you are rendering one movie and scaling it down for two outputs. Faster than rendering two movies.
    If you really want to render fields (I rarely do), you have to drag the 720×540 comp into a D1 or DV comp, and scale it down before rendering. Do not scale in the OM. Do the same by dragging it into a 320×240 comp … but never render fields for the web.
    Does that help?
