Activity › Forums › Adobe Encore DVD › Pixel Aspect Ratio
Pixel Aspect Ratio
Posted by Brian Ew mcnulty on May 5, 2009 at 5:51 pmHi all,
I’m having a problem with my output (Build) in Encore. I’m importing in .avi’s and .mov’s into my project and interpreting the footage so that it reads (SD NTSC (0.9091)). I created the movie file with a DV pixel aspect ratio not square. When I build my project all of my videos are squashed to match TV proportions…am I missing something?
Any help would be great. Thanks in advance.
Brian Ew mcnulty replied 17 years, 5 months ago 2 Members · 12 Replies -
Joe Bowden
May 5, 2009 at 8:22 pmSo your original footage is HD in AE? Are the sides cropped out in the comp, or is it letterboxed?
Regarding Flash, it only supports square pixels. And you exported an AVI/MOV from Flash?
Do you want a 4:3 project, or 16:9? I’d think the latter would be better suited, but if that’s not what you want, you’ll have some work to do in AE.
Brian Ew mcnulty
May 5, 2009 at 8:27 pmThe sides are cropped out in AE. Yes, flash is square-pixel based so not too concerned with that one, just the .mov and .avi that I created in AE at 720×480. Do I have to make them 720×540 and when it goes into Encore it will compress the file to 720×480? Someone mentioned this…
Yes, I want the file at 4:3. Where else in Encore would it allow me to get the correct ratio? When I click on the button that says, “Correct Menu Pixels for TV Display”, that’s really what it looks like. Even after I make sure the “Interpret Footage” is correct and “Edit Quality Presets” are correct.
Joe Bowden
May 5, 2009 at 8:28 pmThese were all exported from Flash? Or are the first three video files? If so, how were they captured?
Brian Ew mcnulty
May 5, 2009 at 8:32 pmI created the larger file in Flash and then converted it. The other three were created in AE. I made sure I had the Comp Settings set at 720×480/ NTSC DV. The footage (limited) was created from an HD camera and the rest was created in AE.
Everything is squashed as if it were all square pixels…
I need this DVD as a presentation tool for TV and a comp monitor.
Thx.
Joe Bowden
May 5, 2009 at 8:50 pmIf you have an NTSC DV 4:3 project in AE and your HD video is cropped, then when you export, it should already be 720×480 with PAR of 0.9. The video you export should display correctly in Encore as 4:3 SD video by default, with no need to add PAR correction from Encore.
This is not the case?
You should also import your Flash video into an NTSC DV 4:3 DV project, crop it to the 4:3 frame there, and export this as 720×480 with PAR of 0.9.
Brian Ew mcnulty
May 5, 2009 at 8:54 pmIt will show correctly actually on screen unless I see what it will look like on TV settings (button I mentioned). That’s just a viewer though and doesn’t do anything to the aspect ratio. When I play the video’s separate they are correct. When in Encore and built they become what appears to me as a square-pixel aspect ratio…even though it isn’t.
I will try the Flash conversion as well. Thx.
The video’s that aren’t showing correctly indicate that the PAR being used is correct as well.
Joe Bowden
May 5, 2009 at 9:29 pmAny chance you could post some screenshots somewhere and link them to here so I can see what you’re talking about?
Brian Ew mcnulty
May 5, 2009 at 9:44 pmI believe the image uploaded correctly. It shows the screen size is 655×480.
