Activity Forums Apple Final Cut Pro Legacy pixel aspect interpretation settings?
  • pixel aspect interpretation settings?
    Posted by Tristan Summers on July 21, 2010 at 1:17 pm
    Hello.
    This musty be covered somewhere but I am yet to find it.
    I am wondering if it is possible to change an interpretation file somewhere, as at the moment, Final Cut assumes a 1024 or 768 renders to be CCIR PAL pixels AND anamorphic, and I am sick of having to correct each and every file.
    Maybe somebody has a correct interpretation setting somewhere? Maybe even one that works with after effects new correct pixel ratios?
    Ideally, I would like ALL files to be left alone i.e. set to square pixels so I can update them if necessary, as it seems FCP can’t manage to get it right.
    Perhaps there is a plug in that actually reads the metadata in the quicktime file?
    cheers
    Tristan
    Jeremy Garchow replied 16 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    July 21, 2010 at 3:34 pm
    [Tristan Summers] “and I am sick of having to correct each and every file. “
    FCP doesn’t like to work with ‘non-standard’ frame sizes and you couldn’t layoff 1024×768 to tape, so FCP assumes you are working in PAL widescreen.
    You can change all of your clips in a batch by selecting them in the browser, fine the Pixel Aspect column and right click and choose, square. You can do the same for anamorphic, right click and choose ‘no’.
    Jeremy
