Activity Forums Maxon Cinema 4D Pivot point ?
  • Pivot point ?
    Posted by Tom on May 21, 2007 at 5:18 pm
    I would like to move the “pivot” point to a specific
    part of an object (or group) so I can rotate relatively.
    This would be equivalent to the “Insert key” in maya
    if that helps.
    TH
    Tom replied 19 years, 4 months ago 2 Members · 2 Replies
  • Alejandro Torres
    May 21, 2007 at 7:28 pm
    Hi:
    To move the pivot point just select the two orange arrows in the left panel (standard mode, release ten) and that will indicate the position of the pivot point and you can move it freely with the move tool.
    https://blog.donews.com/images/blog_donews_com/liuyc/c4d-r10.jpg
    Yes, I know this is in Chinese and everything but it’s the only image I found, the button I’m telling you is located in the left panel, just below the character’s eyes. In the image the move object button is selected, the one that’s underneath it would be the move pivot button.
    I assume you have R10 because it seems you just bought it and I don’t have any other version so I can’t help you with them, but I suppose it’s quite the same.
    Alejandro
  • Tom
    May 21, 2007 at 9:38 pm
    Ah, yes…that’s better 🙂
    Thanks for your help. I was expecting something not so
    obvious. And you are correct, R10 is my version.
    Thanks again, cheers.
