Activity › Forums › Adobe Premiere Pro › Pitch Shifter makes audio go out of sync
  • Pitch Shifter makes audio go out of sync
    Posted by Michelle Verdugo on April 10, 2018 at 4:31 pm
    I’m using pitch shifter to make some voices low and others high pitched and the audio wave forms don’t “shift” when the effect is applied. So when the playhead hits the beginning of a waveform, there is a big lag until the audio plays. Makes it hard to edit quickly. Also when it’s exported, the audio seems to shift again and some of the audio gets cut off towards the end of someone talking. It’s such a pain to go in with tweezers and try to get it all synced through trial and error. Please help! I’m using Premiere Pro CC 12 and I’m on a newish Mac laptop running Sierra. I’ve looked at sequence settings and nothing seems amiss there – frame rate on native footage is 30 fps, sequence is 30 fps, audio sample rate is 44100, etc.
    Brian Andersen replied 6 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Michelle Verdugo
    April 10, 2018 at 5:34 pm
    Right??? If only I knew Audition. I suspect I have some crosshairs in the audio tracks and that being precise and keeping it neat and clean (no tracks that have both pitched and non pitched clips) will fix it. I’ll learn Audition and stop messing around soon….
  • Todd Perchert
    April 10, 2018 at 10:19 pm
    Just curious… your footage sample rate is 44100, or sequence rate, or both? Video usually has a sample rate of 48000. Just wondering if you purposely chose 44100.
    TC
  • Michelle Verdugo
    April 11, 2018 at 1:23 am
    I didn’t choose that sequence rate, that’s just what it was. Will circle back once I try 48000 – thanks!
  • Michelle Verdugo
    April 11, 2018 at 12:37 pm
    We are using a macro lens on an iPhone 6 to capture this animation/claymation story. We tried a Canon 5D and some other DSLR’s and found that the iPhone was the best for this project – HO size train models are so tiny. Anyway, from what I’ve read, the iPhone shoots at 30 or 60 fps.
  • Michelle Verdugo
    April 11, 2018 at 12:40 pm
    It appears that Pitch Shifter is the exact same interface in Audition as it is in Premiere. Why is Audition better to use for this? Just curious. thanks!
  • Michelle Verdugo
    April 11, 2018 at 12:46 pm
    … and the audio is recorded with the Voice Memo app on the iphone so who knows what the frame rate is on that??? It’s a gorilla project – cheap and fast.
  • Todd Perchert
    April 11, 2018 at 6:49 pm
    I’m afraid Dave is right. Even if the new PPro version works better with the variable rates, the plugins may still have difficulty. You may want to convert to something a little friendlier. Give Handbrake a try or you can try transcoding with AME and see if you get something in sync, then apply effects.
    Good Luck!
    TC
  • Brian Andersen
    January 24, 2020 at 6:54 am
    If it’s any consolation, I am having the same issue in Audition in 2020.
