Activity Forums VEGAS Pro Pitch Control Help
  • Pitch Control Help
    Posted by Carson Young on February 2, 2007 at 5:26 am
    If i remember correctly with pitch control. i select the audio track, hold in shift and hit the – (minus) key, and my audio file should drop an octive. For some reason this is not working for me. Any ideas, or settings i may need to check?
    Thanx, Carson
    Carson Young replied 19 years, 7 months ago 2 Members · 2 Replies
  • Peter Wright
    February 2, 2007 at 6:12 am
    Yes, you are doing it right – can you see “-12” on the waveform event?
    If not, enable View > Active Take Information (Ctrl/Shift I)
    For the record:
    – or + buttons on their own change pitch a semitone at a time
    Ctrl – or Ctrl + changes pitch One Hundredth of a semitone at a time
    Shift – or Shift + changes pitch 12 semitones, or one octave.
    Make sure you select the audio event first.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Carson Young
    February 2, 2007 at 6:19 am
    got it! works like a charm, just had to enable the feature.
    Much Thanx!!
