Activity › Forums › Adobe Audition › Pitch changes on its own
  • Pitch changes on its own
    Posted by Sam Behrens on April 5, 2005 at 5:03 am
    I am trying to stretch a section without changing the pitch. Admittedly, I am fairly new at this, but I’m pretty sure I’m doing it right (well, I guess not since it’s not working). When I play the stretched clip in edit mode, or when I preview the new (stretched) clip, it plays fine. When I play it in multi-track mode it plays an octive higher.
    Much thanks.
    Sam Behrens
    Willie Toth replied 21 years, 6 months ago 2 Members · 1 Reply
  • Willie Toth
    April 5, 2005 at 1:31 pm
    Sam,
    You are doing it right, but I think you are confusing pitch with speed … The effect is only present in the multi track side and is not mixed down to the track until you do the actual mixdown … When you make a clip shorter it speeds up the sound, but it’s in the same pitch … On the converse side of this world, when you stretch a clip it slows the voice and or music down but as when you shorten it, the pitch still remains the same ………. WILLIE
